Michael Tyler – UV Light-Up Display
I’m Michael Tyler and for the last 7 years I have been creating Vectric’s Free monthly projects. I’ve made everything from spring wreaths and mantle clocks to snow sledges and cheeseboards.
Did you know there are already 83 projects free for Vectric customers to take advantage of and we’re working on more every month! Each project comes with the file(s) for you to download, along with a PDF document that highlights some of the key important steps to help you get through your project. Plus all new 2018 free projects come with their own video that tells the story of the project from start to finish.
The “Hidden Seed” is a captivating art piece for your home decor! The project incorporates UV LED light strips to light up the interior of the cut-away view of a sprouting seed. The UV light reacts with the materials used in the project to produce an extraordinary and satisfying glow effect!
This project was designed using the Vectric Aspire software. Models were saved as a composite STL file in order to be able to import the model into the VCarve software.
Suitable for version 9.5 or greater
